Right - which is the "negative" (PCM) side of the IAC circuit. (white w/ blue tracer)
Originally Posted by 575cat
(Post 4538324)
Talked to Eddie Young a couple weeks ago and he says the red w blue tracer is already fused along with some other components so I will put it on the white w blue tracer according to his diagram .
Originally Posted by ALL_IN!
(Post 4538191)
Hey, GF?, I've been looking at the wiring diagram tonight. The PCM controls the ground for the IAC (as well as other controls). The 12v source is shared with the boost controller. This 12v source is supplied through the fuse from the Main Power Relay. I don't see how a 1A fuse on the 12v source is going to to protect the PCM, as they are not connected. A high amperage situation on the negative side of the IAC could result in damage to the PCM.
Would you further explain your logic. I appreciate it! Terry GF? |
Originally Posted by VoodooRob
(Post 4520208)
From what I have gathered from this site, low voltage will destroy the PCM, 10 or 15 amp lets too much thru, 1 amp will save the PCM. Am I correct people in the know?
(Post 4520190)
Do you think a 10 or 15 amp fuse would be better ?
GF? |
Just some of jist --- The red / blue wire is the IAC connection / feed to the IAC by pass valve. That also is spliced up to the area of 4 fuses 20 to 25 amp.
The IAC -- white / blue wire goes to the PCM connector B. -- That's the middle connector on the PCM |
1 Attachment(s)
Had a PM asking, so I wanted to just post a followup, this is what I made for mine. I should have made the harness shorter, but it was a little easier to assemble at this length.
1 Amp fuse. [ATTACH=CONFIG]567621[/ATTACH] |
ALL_IN!, nice setup, would you mind sharing the part number / source of the connectors you used? I've searched in the past and never could find the male/receptacle side.
Thank you, GF? |
It took me a while to find them too. ...quite a while, in fact. I work in the auto industry, so I had to reach out to some of my resources for some part numbers.
The connector bodies are .... AMP SSC-2 Black Female AMP SSC-2 Black Male Usually, you have to buy like 5 million of them to get the 4 I needed. But I found a website.... www.CycleTerminal.com ...that sells smaller quantities, and even has kits with the terminals, locks, and seals. I already had the proper crimper for the metri-pack / superseal type terminals. About $20 or so in the two that I made. The 1 amp fuses are also hard to locate, locally. So Amazon was the source.
Originally Posted by Got Freedom?
(Post 4556070)
Thank you, GF? |
I could not find 1 amps also so I went with 2 amp .
Try Amazon. I believe you would be safer with 1 amp vs 2 amp. But I don't know if anyone knows for sure. The 1 amps have evidently been holding up to the IAC amperage draw under normal conditions.
(Post 4556695)
| All times are GMT -5. The time now is 06:23 PM. |
