-   -   Sea strainer install question (https://www.offshoreonly.com/forums/general-q/344114-sea-strainer-install-question.html)
Bajajay98 01-22-2017 08:19 AM
I'm going to be installing a sea strainer on my boat this winter, been seeing many pictures with valves installed on the sea strainer, is the reason for when you open the top to clean the water from the engine side doesn't back flow and over flow to sea strainer ? Which side of the strainer should I put the valve on ? Drive side or engine/pump side ? Or do I not even need one ?
F-2 Speedy 01-22-2017 08:31 AM
If your running a bravo type drive I don't think their needed, if running transom mounted pickup then yes, if you do install one put it in between the pickup and the strainer,
Bajajay98 01-22-2017 08:33 AM
Okay sounds good
Crude Intentions 01-22-2017 10:12 AM
Also wether running outdrive pickup or thru hull the valve is good for flushing. I added strainers to mine and have valves that will be turned off when running on hose. All the water fed to the strainer can be sucked up by the pump.
Unlimited jd 01-22-2017 11:16 AM
Valve right at the pickup is great if a hose breaks or falls off. Completely useless anywhere else if the same happens. I like valves on all through hulls below the water line, right at the fitting.
