-   -   P5 Hydromotive Props on Formula 382 with 500 EFI (https://www.offshoreonly.com/forums/general-q/344217-p5-hydromotive-props-formula-382-500-efi.html)
poulsen11@yahoo. 01-26-2017 03:14 PM
Anyone have 5 blades on their 382 with 500EFIs? What pitch are the 5 blades?
Was thinking about trading out my bravo 4 blade 28p's for some 5 blade hydromotive 25p
Do you think the hydromotives will hit my rev limiter hard with the reduced pitch?
poulsen11@yahoo. 01-27-2017 04:40 PM
Anyone?
Padraig 01-27-2017 06:13 PM
What are you running now and what RPMs?
poulsen11@yahoo. 01-28-2017 06:57 AM
Bravo 4 bllade 28p maxxing out at about 5150 rpm torque limited not rev limiter.
Wilks 01-28-2017 07:55 AM
Go with p5x. The 382 needs bow lift
poulsen11@yahoo. 01-28-2017 08:31 AM
It's more the pitch I am asking about. Does a 25p 5 blade=a 28p 4 blade from an rpm perspective?
Padraig 01-28-2017 09:37 AM
Give Tom at Hydromotive a call for good info. I have always found him knowledgeable and very willing to discuss props.
Padraig
JRider 01-28-2017 11:27 AM
I can tell you a 4 blade hydro to 4 blade bravo comparison, if you are running a 28 b1 now a 27 hydromotive Q4 would RPM about the same. The Q4s are also are larger diameter than bravos, that is a factor. So, add another blade and drop another inch in pitch would make it a 26 to be about equal rpm. that is kinda rule of thumb, add a blade drop an inch of pitch. You really will not know unless you try them.
