Who's got a desk top dyno?
Now that I have all the major pieces bought, can you plug it in and see what it says,, or anybody have any good guestimates?
454 8.5 compression, 731 cam, promaxx 320's, ( Intake .200 = 155cfm, .300 = 228, .400 = 289, .500 = 336, .600 = 368, .700 = 388 .800 = 392 exh .200 = 117, .300 = 158, .400 = 205, .500 = 228, .600 = 258 (w pipe 277) .700 = 260, (280) .800 = 261 (283)... 1050 dom on a 177 blower, 5psi. |
No desktop dyno, but I would guesstimate around 580hp @5400 rpms.
put it together bring it up to michigan, 30 min north of detroit this time of the year my "real" dyno is looking for jobs to run
567.3
I modeled a 525 SC then changed the heads to your flow numbers, swapped cams and raised the compression. It shows 617 HP.
Originally Posted by bobl
(Post 4526548)
Originally Posted by phragle
(Post 4526554)
Oh boy.... I think Im going to need a bigger prop.... :party-smiley-004:
yeah, that too... when I replaced the lower 2 years ago, the propshaft and the vertical shaft both had twisted splines
What you have in it for power now and what kind of speeds are you running ?
If I throw the little pulley on and a 2" shorty, the bam speed calculator thing predicts top speed somewhere between the mortuary and the crematorium....
Originally Posted by tommymonza
(Post 4526569)
(Post 4526034)
454 8.5 compression, 731 cam, promaxx 320's, ( Intake .200 = 155cfm, .300 = 228, .400 = 289, .500 = 336, .600 = 368, .700 = 388 .800 = 392 exh .200 = 117, .300 = 158, .400 = 205, .500 = 228, .600 = 258 (w pipe 277) .700 = 260, (280) .800 = 261 (283)... 1050 dom on a 177 blower, 5psi. Seriously though. Those heads are flowing as good if not better than a set of afr 305's. Those are real flow numbers, not "advertised". I gotta do some stuff around the house right now, but I'll try and run it in my program for you as well. The 731 cam is gonna be a bit on the small side to get in the upper 5000's for peak power. I'd probably would have gone with the 525EFI or 741 cam. I could compare the two , and see how they stack up power wise. Shooting from the hip, I think you'll easily get over 600 without a problem. Wayne272 build a set of those engines, but had a 236/245 114 crane Flat tappet, 177 blower, dominator, stock Merc heads, and made 575ish around 5500, with around 4.5lbs of boost. Torque was 600ish ft lbs. |
Originally Posted by MILD THUNDER
(Post 4526576)
You should have said "AFR" heads. The HP guesses would have been 650+. lol
^^^ isn`t it basically the same motor that made 690hp as Phragles? Why is your guess is 130hp less?
My guess: 688hp |
Should be interesting to see how the promaxx heads work out. Could be a nice option.
Phragly, you gonna dyno it ? |
Originally Posted by ICDEDPPL
(Post 4526591)
My guess: 688hp |
(Post 4526591)
My guess: 688hp |
The plan is to dyno it....and get a good solid base tune. I would also like to see if the tune stays consistent if I swap to the glory pulley....
I told her last night I wanted to swap "Glory pulleys" I have 2 black eyes this morning!!! :hijack::evilb::lolhit::thankyouthankyou:
(Post 4526570)
That will be a nice build regardless but I'd say griff would pretty close estimate.
I got 630hp with that combo, and 612HP, with the stock 525sc camshaft in it.
Stock 525sc cam, was 228/236 114 LSA .530/.551 731 cam, is 226/236 112 LSA. .587/.610 That would make sense to me. If I recall, griff replaced his stock flat tappet cam in his 525sc, for the 731, and picked up about 100rpm. Thats probably around 20-25hp gain. Cams are fairly similar duration wise, a bit more lift /lifter acceleration with the roller design. Thats about what I think should be expected when going from a flat tappet to hyd roller cam. Its certainly not 50+HP like some may suggest. Thats figured with small headers and right about 5lbs boost. I am sure if its dynoed with big tube dyno headers , those numbers will be higher. Prob 650 plus with the 731 cam, dyno headers, etc. |
(Post 4526955)
Stock 525sc cam, was 228/236 114 LSA .530/.551 731 cam, is 226/236 112 LSA. .587/.610 That would make sense to me. If I recall, griff replaced his stock flat tappet cam in his 525sc, for the 731, and picked up about 100rpm. Thats probably around 20-25hp gain. Cams are fairly similar duration wise, a bit more lift /lifter acceleration with the roller design. Thats about what I think should be expected when going from a flat tappet to hyd roller cam. Its certainly not 50+HP like some may suggest. Thats figured with small headers and right about 5lbs boost. I am sure if its dynoed with big tube dyno headers , those numbers will be higher. Prob 650 plus with the 731 cam, dyno headers, etc. I was running the stock bottom end with 7.5 CR pistons and about 7.5# of boost. I estimated I was around 560-570hp. I figure the extra boost I had and his 1 point higher CR are pretty much a wash for HP. I'm not sure how much the promaxx heads will gain hp wise. Maybe 20-30hp??? |
so what kind of speed you thinking?
TRS right? set deep? 77mph |
(Post 4526969)
(Post 4526955)
Rob what exhaust you have on there?
I have a set of stainless marines, with regular risers and a set thats dry to the tip. I would like to get by with the standard risers if possible so I dont become that guy with the noisy azz boat.
(Post 4526992)
(Post 4526975)
Bravo, set in the middle......
(Post 4527092)
So maybe 80?
(Post 4527102)
if ALL the stars align... but I am pretty much counting on mid 70's
Going to need to Wear your Special helmet. |
(Post 4527102)
Originally Posted by SFOcean
(Post 4527213)
It will do that with 450 at the prop.
Time to update the life insurance... |
You have full hydraulic steering, so no big deal; I saw your video, LOL.
| All times are GMT -5. The time now is 07:51 PM. |
