-   -   HP 500 Rebuild expertise (https://www.offshoreonly.com/forums/general-q/344516-hp-500-rebuild-expertise.html)
mike tkach 02-07-2017 07:58 PM
that sure is not a hp 500 carb cam,i don,t see all the specs so i can,t say for sure that is the problem but i would bet it is.is it a step nose or flat nose cam?169611 crane cam is what a hp 500 carbed engine came with.if you install one you won,t need to go with a dry exhaust,but the sound of dry exhaust is sweet ,until you get you,r first noise ticket.
mike tkach 02-07-2017 08:03 PM
that sure is not a hp 500 carb cam,i don,t see all the specs so i can,t say for sure that is the problem but i would bet it is.is it a step nose or flat nose cam?169611 crane cam is what a hp 500 carbed engine came with.if you install one you won,t need to go with a dry exhaust,but the sound of dry exhaust is sweet ,until you get you,r first noise ticket.cam cost 424.09 at summit.
mike tkach 02-07-2017 08:06 PM
i would get a hp 500 efi cam for the engine,it and you will be happier.
getrdunn 02-07-2017 08:06 PM
That cam posted is a 502/415 hp mpi cam isn't it.
mike tkach 02-07-2017 08:26 PM
if it is it was installed wrong,the 415/502 cam is not a reverter.
1989mach1 02-07-2017 08:50 PM
Not to hijack here but have a quick question and don't think I have seen a cam thread in some time.....
I have 500efis with top ends done not long ago let's say 50 hours. Could I swap the 500 cams for 525 efi cams with out changing any thing else? Or will some changes to springs and such be needed as well?
getrdunn 02-07-2017 08:53 PM
1 Attachment(s)
here u go. Sure exhaust isn't cracked?
mike tkach 02-07-2017 09:00 PM
I have 500efis with top ends done not long ago let's say 50 hours. Could I swap the 500 cams for 525 efi cams with out changing any thing else? Or with some changes to springs and such be needed as well?
yes.it may need a computer reflash.
