K/E Spring Oilers
Has anyone used the K/E spring oiler set-up and if so what is your opinion of it? The price isn't terrible and seeing that I'm pulling the engines this spring I'm thinking about adding these.
Originally Posted by endeavour32
(Post 4527947)
dan used them on his engines,maybe he will chime in,imo spring oilers are a good thing for a marine endurance engine.
Thanks guys. I'm going to get the at least one of the headers mounted so I can check the clearance between it and the valve cover. I'm sure I'll be ok because the Eickerts have a narrower profile than a manifold that has to to have a riser bolted to it.
You going to Dyno them Mike?
Has anyone checked how hot their springs got running hard in a marine hydraulic roller application? After a several mile run at close to 6000 rpms I could hold my finger on mine without it being uncomfortable.
Originally Posted by kvogt
(Post 4527998)
I suppose in circle track engines, where they are running big rpm, hotter engine temps, the spring oilers may be more beneficial. I guess if I had to choose, I'd rather keep my oil temps in check, and no spring oilers, vs higher oil temps, and spring oilers. |
1 Attachment(s)
Would it be safe to assume, that if you are running 250* oil temperature on your gauge, your springs, are probably at 250*, as a minimum? According to pac, thats about 40lbs of open pressure lost, due to the temperature, when compared to what the spring is tested/rated at. By 300 degrees, you're down nearly 60lbs of open pressure.
I'd think keeping those springs under 200 degrees, would be the goal? |
Originally Posted by MILD THUNDER
(Post 4527961)
I think the KE oilers are a great idea and definitely can't hurt that's for sure assuming installation, plumbing etc is A1. My personal position would be is how you have a tendency to run. Wot for etended periods without question. On and off the sticks and not racing then.... I would imagine they would certainly extend valvespring life regardless. I looked into installing these in 496's.
Plumbing for my set up would be easy. My Eickert thermostatic filters heads have the multiple ports to plumb everything.
| All times are GMT -5. The time now is 07:10 AM. |
