-   -   Ditch MerCathode for Anode Protection? (https://www.offshoreonly.com/forums/general-q/344646-ditch-mercathode-anode-protection.html)
Tractionless 02-15-2017 01:34 PM
Originally Posted by AllDodge (Post 4529062)
Anodes will assist in giving more material to sacrifice, but does not do the same job as the mercathode.
I have one of the Merc probes and its a piece of wire that has been platinum coated around a small nylon stick. You could probably get close if you silver plated a 18AWG wire, but not exact due to differences in properties
Thanks for the info.
The 2nd paragraph is what I'm trying to get away from if possible. "Known Knowns" seem to lacking with MerCathode testing and usage. Other than being unreliable and a PITA to test.:D
Crude Intentions 02-15-2017 01:43 PM
These can be helpful. If you're on shorepower or in a marina overnight. Extra protection doesn't hurt.
https://www.google.com/shopping/prod...owpxoCXPvw_wcB
Tractionless 02-15-2017 01:50 PM
I don't fish.........hahaha good idea for extra peace of mind.
getrdunn 02-15-2017 01:56 PM
Originally Posted by Sydwayz (Post 4528483)
Do you ever have the boat in the water, slipped, overnight, etc., WITH the shorepower attached? This is when the Mercathode is most important.
Never gave that a thought.
AllDodge 02-15-2017 02:22 PM
It's real easy to test, after sitting for 24 hours and the boat plugged in connect the probe to the positive connection of a digital multimeter. The other connection goes to boats battery ground. Set meter scale to 2000mV and drop probe in the water within 6 inches of the rear of the drive. There are two types of anodes and yours is listed at the bottom set
a. MODELS WITH ELECTRODE MOUNTED ON BOAT TRANSOM
Fresh Water Areas Salt, Polluted or Mineral Laden Water Areas
Quicksilver VOA Meter 7.5 - 10.5 millivolts 8.8 - 10.5 millivolts
Digital Meter 750 - 1050 millivolts 880 - 1050 millivolts
b. MODELS WITH ELECTRODE MOUNTED ON BOTTOM OF TRANSOM ASSEMBLY
Quicksilver VOA Meter 6.2 - 11.8 millivolts 7.5 - 11.8 millivolts
Digital Meter 620 - 1180 millivolts 750 - 1180 millivolts
Start on page 7A-20.
http://www.boatfix.com/merc/servmanl/14/14a7.pdf
BTW if your not seeing any paint missing off the drive after being in the water my guess is your fine
Crude Intentions 02-15-2017 02:25 PM
I don't either but plenty of friends use them on our overnight runs to marinas just for peace of mind
Tractionless 02-18-2017 07:35 AM
Thanks that's the shorthand version of the manual and much easier to understand. I'll get the boat in the water and see where the MerCathodes stand test-wise before ditching them. Found out a buddy has the Merc. probe that I can borrow so that makes the decision easier at the moment.
79formula 02-19-2017 07:10 AM
I ditched my mercathode system. I do a few overnights a year, and slip it for one full week every summer. No issues at all. I boat in freshwater only.
BUP 02-19-2017 12:19 PM
How fast the anodes are eaten up is something to look into as well. Once 50 % gone they need to be replace asap or sooner.
Tractionless 02-21-2017 01:48 AM
Did you ever test the MerCathode? Did you simply affix anodes in their place? Thanks for your perspective.
10-4 on that, thanks for reiterating what I've read elsewhere. When I bought the boat the hydraulic ram anodes were dark gray and down to the mounting bolts. I immediately installed 4 new units (2 outdrives).
