-   -   flushing without Drives? (https://www.offshoreonly.com/forums/general-q/344681-flushing-without-drives.html)
offthefront 02-13-2017 03:07 PM
Anyone know who makes the plates for Flushing motors without Drives mounted? I know I have seen them ....m
AllDodge 02-13-2017 03:40 PM
Haven't seen one, but think it could be made easy enough with a piece of Plexiglas. Dill 4 holes for the bolts and one for the garden hose quick connect. Need 4 tubes to use as spacers over the bolt studs to take up the distance, then install the nuts. Doesn't need to seal tight
offthefront 02-13-2017 04:05 PM
1 Attachment(s)
made a quick one from plywood .....Actually have a flush port on the transom .... just dont water to back up thru the Transom Assembly and trash the gimbal bearing ....
[ATTACH=CONFIG]564738[/ATTACH]
Unlimited jd 02-13-2017 04:12 PM
It can't back up into where the gimbal bearing is. There a hose through the transom assembly to nipple inside that the 1 1/4" hose connects to and goes to the sea pump, I just take the hose off the nipple and put the garden hose inside it
Tractionless 02-14-2017 02:36 PM
Perko as they have a valve that blocks water from going out the drive side of the pickup hose that you "T" inbetween the drive and impeller pump.
