-   -   plug for 1996 35 fountain lightning (https://www.offshoreonly.com/forums/general-q/345038-plug-1996-35-fountain-lightning.html)
ninjaturtle 02-26-2017 07:15 PM
I found a rectangle plug under the rear seat above the speaker cover with two male prongs, I assume this would be for jumping or charging batteries without opening the engine hatch?
Crude Intentions 02-26-2017 07:23 PM
Yes. Same setup some tow trucks use. Under the seat you should see leads going from that to a battery switch. My other end has the femal plug with a set of jumper cables
ninjaturtle 02-26-2017 07:25 PM
Any marine store have them?
Unlimited jd 02-26-2017 07:28 PM
Not a marine item, jumper cable disconnect. Probably find it on Amazon if not aw direct
ninjaturtle 02-26-2017 07:43 PM
Thank you
tman 02-26-2017 08:38 PM
Found on fork lifts.
ALL_IN! 02-28-2017 03:04 PM
This.
