Manually Degreed Cam Lobes
Looking for manually recorded cam lobe lift vs degrees rotation for any cam lobes. Any idea where to look for this?
i do not understand what you are asking.
Try doing a search (Google or etc) for Cam Dr files, graphs, or etc
As there are a few machines out there, Cam Dr being one, Audie Cam Pro Plus being another, that will measure complete lobes. http://www.audietech.com/images/stor...p_2015_web.jpg |
Grab a handful of Percs and your bound to come up with something. Ha
SB that is pretty cool though but I gotta stick with the old fashion poor mans engine block, degree wheel and dial indicator.
Originally Posted by getrdunn
(Post 4535479)
Cam Dr files or similar from anywhere will never be provided to anyone outside the company that generated them. I been that route. Engine block, degree wheel and dial indicator readings are what I am after.
Originally Posted by Rage
(Post 4535549)
Typically, if you bring your cam to a shop that has a "cam doctor" machine, they simply put the cam on it, and measure the lobes at various points, and give you that data that has been recorded. |
Rage
Not sure exactly what you are looking for. If you plug your cam specs into your modeling software it should give you the profile at various lifts (mine does). Are you trying to validate what it is giving you? I'm sure it's not perfectly accurate because it's just estimating the intensity of the lobe. I just installed the cam in the 502 I'm building. I could profile it for you if you would like. Bob |
| All times are GMT -5. The time now is 12:46 PM. |
