-   -   Needing more total timing 1997 Mecruiser 5.7 (https://www.offshoreonly.com/forums/general-q/345264-needing-more-total-timing-1997-mecruiser-5-7-a.html)
rsvert89 03-08-2017 05:26 PM
1997 Mercruiser 5.7 Alpha, was a 2bbl, non vortec heads. Standard ignition system. The new engine has Vortec heads, Howards Cams Roller cam, Edelbrock RPM Air Gap intake. Standard exhaust manifolds. The cam manufacturer said I want between 32-34 degrees of timing at 2500rpm. Going by the book, and the cover on my engine, it looks like base timing is 8 degrees btdc, and 22 degrees module advance, for a total of 30 degrees. Can I swap modules from a different engine to get to the 32-34 degree range? Anyone know of a particular engine that has that? Thank you in advance.
SB 03-08-2017 05:30 PM
If you have Tbolt IV ignition, just set total degrees where you want it...and let base fall where it falls.
Do you have Tbolt IV or V ? What module # do you have ?
rsvert89 03-08-2017 05:43 PM
I am not sure of my part number. Looks like I have Thunderbolt V, and I believe it says v8-22 on the module
SB 03-08-2017 06:03 PM
Tbolt V uses a mean best timing set up...using a knock sensor and tachometer......so very unconventional. It also has a special procedure to check base timing because of all of this. Do a search on it in google land to learn more...I'd have to write a small book to let you know all it's workings.
Tbolt IV is conventional...ie: doesn't adust for anuthing...just has an electronic advance.
rsvert89 03-08-2017 06:34 PM
I know mine does not have a knock sensor. I have timed it before and there was a sequence of grounding a wire to set base timing if I remember correctly. Is it hard to switch to thunderbolt iv? Would my distributor be ok, and just change module/sensor in the distributor? Thank you for the help.
SB 03-08-2017 07:58 PM
I could be wrong, but I have not seen a Tbolt V without a knock sensor.
Here, go nuts: :)
http://www.boatfix.com/merc/Servmanl/16/16B4R2.PDF
Edit in: oh, you would have to swap the module harness to go from a V to a IV.
rsvert89 03-08-2017 07:59 PM
Found a module from a thunderbolt IV that is V8-24. Anyone know if the wiring is the same?
SB 03-08-2017 08:00 PM
Look up , we posted at same time...lol.
Griff 03-09-2017 01:04 AM
From what I have read, Vortec heads do not like more than about 30* of timing.
Trash 03-09-2017 12:27 PM
I would characterize it as not that they don't like more than 30* of timing but rather they don't respond as much to timing over that amount. I would still target 32*.
Mr Maine 03-09-2017 01:50 PM
I agree, 30 to 32 max. 32 is what I run on my with no issue. I believe the 350 vortec trucks only had something like 26 total timing.
Just bump your initial timing from 8 to 10 and that should give you the 32 total you want. I always check my total timing, but I have thunder bolt iv ignitions.
Bondo 03-10-2017 08:04 AM
Ayuh,..... Agreed,... Set it in base timin' mode, 'n the T-Bolt V will take over after ya take it outa base mode,...
Some T-Bolt Vs came without the knock sensor, but it can be added,....
rsvert89 03-11-2017 09:01 AM
Thanks for all the help everyone. I will lock into base mode, set it a 10 degrees. That should get me the 32 total I need.
