-   -   Source or cross reference for merc 502/500 fuel pump harness end (https://www.offshoreonly.com/forums/general-q/345503-source-cross-reference-merc-502-500-fuel-pump-harness-end.html)
articfriends 03-16-2017 04:32 PM
1 Attachment(s)
In middle of outfitting a efi motor on my dyno, im trying to find if anyone has ever cross referenced a gm harness end for fuel pump. Im setting dyno up and want to build a pigtail to trigger a relay or power a fuel pump WITHOUT butchering up mefi harnesses. I have a complete cool fuel pump i can cut wires off for this but really dont want to. Just spent 2 hrs at local auto parts store looking thru gm repair harness ends and found nothing.
articfriends 03-16-2017 04:33 PM
It would be the black end not in my fingers, says "ped 6" on it
Kefurr 03-16-2017 05:10 PM
Take a look here
https://www.acdelcotechconnect.com/p...tails-catalog/
bck 03-16-2017 05:12 PM
Try Metri Pack 280 for that style connector. Try an oem # 15300002 if needed. But just the 280 series should take you to what you need.
whiskeytango 03-20-2017 03:20 PM
Definitely looks like 280 plug
whiskeytango 03-20-2017 03:30 PM
I can make you up a pigtail if you need it. Let me know.
articfriends 03-20-2017 06:35 PM
I ordered a male/female end offthe info given by bck, should be here tommorrow. when i search it on ebay from the 153 number some show two round male prongs in connector, some show the flat similar to what im looking for, we'll see when it shows up!
bck 03-20-2017 06:42 PM
As long as it's a metri pack 280 I think you'll be good. If you ordered male and female then worst case is you have to replace both and it'll work, right?
