J tubes
any issues replacing them on a holley
nope,they come out pretty easy.
Don't need them
Its my understanding you do ^^^^ in a marine environment.
Patients though. I use a little dowel or punch on the standard tubes and slip in so when you grip and turn you don't crimp the tube. Also reinstalling new ones I like to use a little blue loctite just to make sure they don't end up spitting out an exhaust valve or worse yet transferring from one bank to another. But like mike said they typically come out with a little twist and pull action.
(Post 4539244)
Not required |
I have one on each carb that has a small crack, so for 30 bucks its piece of mind...........thanks guys
are you sure they are cracked,most have a slit or hole in them facing the carb in the middle of the bend.
Originally Posted by mike tkach
(Post 4539273)
I bought an HP750 and a HP1000 cfm from AED, they turned the tubes 180 degrees with the small side facing the middle. They said the coast guard approved that setup.
