-   -   Prop Question (https://www.offshoreonly.com/forums/general-q/34569-prop-question.html)
Triple Trouble 10-09-2002 10:28 PM
Prop Question
1 Attachment(s)
Since, my old lowers kept blowing the paint and filler off of the nose cones, I have installed new Imco Lowers with the cast in low water p/u and nose cones. I need some help with new props as I can spin 5500+ rpm. My current setup is what came from the factory. 525sc's, 1:36 gears, 27 pitch 3-blade bravo's. 11,500lbs.
RPM'S are up 350 from the previous drives, Should I just repitch or try something new?:)
HOUSTONPROP 10-10-2002 12:31 AM
you just need dialed in on the props.
look's great!!!!!! work the mirage props and we have a great fall /christmas special going on right now basic repair on props polished 99.00 each or lab finished polished 150.00 we will match all three props exactly.:)
