Thermostat housings
Anyone used the mpi version on a carb? Seems like it would be fine. They are much cleaner looking than the carb one.
not sure which one you mean, but when I converted my 98 to carb used the same one, now did have procharger so pretty sure it was different...
Look at say the hp500. Has a tall convoluted one. The mpi one is low profile and comes forward.
If you are referencing the one I show below, most definitely have used them in carb'd applications
Edit in: make sure the thermostat spacer is installed in correct orientation if you install one of these. It is a water diverter too, so very improtant. http://www.iboats.com/mall/image/ven...8-1989_big.jpg |
That's the one. Thanks. Much cleaner look. However I'm going powdercoated. Lol
Just between me and you Bob Madera helped design that one, you should be good to go there . Best housing on the market .
I`d ask if you can powdercoat it thou, might throw off the thermal stabilization of the metal. |
That's a nice looking piece. It's always a shame to put ordinary rubber hose and crappy automotive hose clamps on it though, lol. Is there a nicer clamp set up between the cheap hose clamps and fancy stainless steel lines?
