Originally Posted by rob vanharten
(Post 4542287)
So speaking of cams, what would be some suggestions to take full advantage of my new heads, comp ratio, and keeping good valve train reliability and a hydraulic is a must. I cannot remove the valve covers with the motors in the boat! And what hp gains would be seen over my current cams??
Your builds going to be perfect for this summer. I would recommend giving Norm a call at least, maybe fill out his online form first. If you like chatting with him next step is decide how much power increase would make you buy a set? 20+hp a side is well worth the cost IMO. You can easily sell your carbs for good money, plus your reliability stays the same. |
It definitely be worth the test to try each carb, especially if Norm is willing to do that free of charge. I'd be trying both carbs, see what happens, then make a decision. Its a no lose situation.
Which model dominator did you get Rob? Not all dominators are the same. Just booster design can have a huge impact in the carb's performance. An Annular high gain style booster, can make much better torque down low, and sometimes better top end HP, then a down leg. |
Originally Posted by MILD THUNDER
(Post 4542331)
Originally Posted by 5050
(Post 4542322)
big cube engines like a wider lobe sep. I think 114 would be better to carry torque flatter and longer without drop off and more lift where the sweet spot of flow is in heads. Torque is what pushing a prop. I'm gonna say ur set up will be close to this pic dyno sheet. Zz572/620 in my last boat. Engines wouldn't pull past 5450 in my last boat [ATTACH=CONFIG]565973[/ATTACH]
(Post 4542326)
Icdeppl's 548ci 900hp carb'd roots engines. Twin 1050 quick fuels, out of the box idle circuitry. Engines stone cold after startup in this video. He runs no water stats, so the engines never build any heat in them. They will idle at 950 in nuetral, 700 in gear, and idle all day long without fouling a plug, or stalling while shifting around the dock with 17.75" cleaver props.. I've seen some high end big name built 900hp roots engines, that surge like a MF'er, stall out when shifting around the docks, blacken the transom after 1 day on the water.
Originally Posted by SB
(Post 4542344)
Does he have the Daytona Sensor's ignition box also ? I forget.
Originally Posted by articfriends
(Post 4542333)
Exactly, a no lose proposition, 1 of 3 results, modern dom beats it, they are same, 4150 beats it but by how much? Like i said though, my 548 ISNT the first motor in the 600 to 850 hp range that one of his 4150's has walked away from a dominator, we can theorize, guess, tell our opinions, talk about our favorite carb but in the end having a high end carb builder bring his carb to dyno then personally tune it, goes from a discussion to real world. I would love to see this happen!!
Most of the stuff I've dealt with tinkering, has mainly been supercharged marine stuff. I have a question regarding the N/A stuff, and carb/intake relationship. I see alot of guys here stick to 4150 intake setups. Its typical they add 2" of carb spacer to the manifold, and pick up power. How come nobody runs an intake like a Profiler, that pretty much has a built in spacer in it? Seems like most respond favorably to more plenum volume. Seems like when you get into the 540, 572, 598 ci , 6000rpm big blocks, especially ones with higher static compression, proper cam, good heads, good exhaust, all netting a good volumetric efficiency , the CFM requirement is up there, in the 1000-1100 range. It be cool to see how a 572 like Rob's, does with a 1050 dominator, 1170cfm custom 4150 from Norm, then bolt on say, an out of the box 850 carb. Seems like in the racing world , when the big cube big block chevy's start getting into the 700+hp range, most builders go for the 4500 series carb, unless they are class limited to a 4150. Most of the guys over on speedtalk claim they have seen the dominator almost always beat out the 4150 carbs at that level when dyno testing . But, they also aren't running a 4150 that flows 1170cfm from a guy like Norm. If we took norms carb out of the equation , it seems like Tims 4150 quick fuel thats rated at 1050cfm, was comparable in power to the 1050 dominator it was tested against. On a 650ish hp engine combo with those carbs. It be interesting to see what would happen, if those carbs were bolted on a setup making say, in the 750hp range. Im sure if we bolted them on a combo thats making in the 500hp range, it be a no brainer the 4150 would likely be the winner. |
1 Attachment(s)
I posted this a while back in another thread. Figured it might be relevent to this discussion
(Post 4542353)
For sure. That be an awesome test. As was yours . The more testing we do, the more we learn. For years and years, I kept hearing about how roots blowers make intake air temps of 200 plus degrees, and intercoolers on them make it soo much cooler , but nobody ever had any actual intake air temp readings to back it up when you asked them. Not even some of the blower companies or intercooler companies. Then we go and start putting intake air temp gauges in our intake manifolds, and find out that a 10-71 setup with no intercooler, isn't even barely at 140 degrees in the intake at 6000rpm in the boat. And that with a intercooler, the iat temps on the roots were as low or comparable to a intercooled centrifugal setup in some other boats.
(Post 4542348)
Yes. We played around with the idle timing quite a bit, and got it pretty much where it seems happiest.
The more dialed in you can get the ign, the more dialed in you can get the carb. |
(Post 4542331)
Norm loves aerosol carbs, he even sends a personal note in the return shipping as to his enjoyment he had working on them...........
(Post 4542391)
I would love to see tims QF1050 on a 750, 850, 950 hp motor against a 1050 dom, if they both made 654/655 hp on my 548, they both flow 1050 cfm at same flow standard is there any reason the equal flowing dominator other than looking cool should out perform it anywhere?
Like you said earlier, its not just the cfm rating. How the fuel is atomized, distributed, etc. If the 4150 style carbs were all thats needed for a 750hp deal, holley, quick fuel, demon, prosystems, and many others wouldnt have sold many dominators. Bck here made more power with a dominator on his 540 after swapping the 4150 carbs and what not . Heres a good read from prosystems about this topic https://prosystems.websitetoolbox.co...in-cfm-6223685 |
(Post 4542393)
And this would help the carburetor tuning for sure.
The more dialed in you can get the ign, the more dialed in you can get the carb. With that being said, do i think they are hands down the best carb for every application, no. And once in the boat, they need some adjusting for sure. As have most carbs ive seen, after they come off the dyno |
Anyone have $1800 to burn ? Would love to see real world tests on one of these. ;)
http://www.silverbackcarbs.com/index.php http://www.silverbackcarbs.com/images/fly1.jpg |
(Post 4542457)
(Post 4542457)
Any of you guys follow the annual carb shootout amongst the various big names in carbs ?
(Post 4542473)
(Post 4542475)
Not the last one...you have a link ?
If i recall, in the 2012 one, quick fuel took first place in the out of the box class, and big block chevy class. Maybe it was aed. Ill try and find it later when im home |
Don't worry about it, I assumed you meant there was one recently. I followed the 1st one when it went down.
Mild Thunder - thanks for the links for the single carb intake induction and prosystems post, very interesting.
Rob - Cool build! Looking forward to seeing how this one turns out - especially if you compare a 4150 carb to a dominator on the dyno. I'm going to try 2200 CFM throttle bodies with an HVH style 4500->4150 modified spacer on my Brodix HVH 4150 intakes vs. my current 1000 Holley TB's. Similar to Smitty's testing, but I don't have the dominator intake... which may help my flow velocity. I'm not pulling engines, but I do plan to do as close to back to back water tests as possible. I only question whether 2200 is WAY too much throttle plate, but according to Prosystems - maybe not. |
Originally Posted by Tibbstoy2
(Post 4542504)
Rob - Cool build! Looking forward to seeing how this one turns out - especially if you compare a 4150 carb to a dominator on the dyno. I'm going to try 2200 CFM throttle bodies with an HVH style 4500->4150 modified spacer on my Brodix HVH 4150 intakes vs. my current 1000 Holley TB's. Similar to Smitty's testing, but I don't have the dominator intake... which may help my flow velocity. I'm not pulling engines, but I do plan to do as close to back to back water tests as possible. I only question whether 2200 is WAY too much throttle plate, but according to Prosystems - maybe not. EZ striper also said they had idle issues with the 2200 when they ran one, I havent worried abput idle yet on dyno |
(Post 4542536)
Well, again, AFTER tayloring timing curve and tweaking afrs I was able to gain 10-12 solid hp at wot over the best carb I dynoed with BUT I also found that last 10 hp by pulling 1 to 2 degrees of timing out on top past my highest amount so carb might have done that if it had a timing table like a efi does, I was able to beat my best corrected and observed tq by about 4-5 ft lbs but I still havent found the 20+ ft lbs I lost down low from 3000-4600. I did some steady state testing at 4400 wondering IF giving tb less than wot would bring back tq, it did not. Testing with a single blade TB thats supposed to flow slightly less tomorrow, would really like to test with a 1600 cfm TB to see if that torque would come back or if carb simply worked better at those rpms, going to be intersteing to hear what YOU find, Smitty
EZ striper also said they had idle issues with the 2200 when they ran one, I havent worried abput idle yet on dyno How much are the injectors tipped (if any) on your dominator intake? I've been told that getting them to fire as much as possible at the back of the intake valve is a must to avoid spraying the runner wall like some of the aftermarket package deal offerings are. Here is what I ended up doing with Brodix 4150 intake (basically did it to figure how I needed to machine my intakes and fuel rails): https://lh3.googleusercontent.com/-i...2Bassembly.jpg https://lh3.googleusercontent.com/-1...keassembly.JPG Based on this, I found I could get 14 degrees of tilt on mine and still be able to install the rails: https://lh3.googleusercontent.com/-B...ont%2Bview.jpg I'm trying to get out in front of the idle issues with the 2200... KVOGT on here got his blower motors with dual 2100's to work with Holley EFI nicely. I'm going to try the same alpha-N idle/speed density cruise to top end combo strategy he's using out of the gate... Even if it does auto-tune properly, it gives me a lot of table resolution to really focus on the tip-in event on those big throttle blades. |
(Post 4542255)
Smitty, that is very generous!! My new Holley 1050's literally just showed up today...Are you offering a dyno service? I am also having Jim doing these custom 4150-4500 adapters. I feel like I am to far along to switch up now but they sound like they rock!!! I read your 548 post and they sure proved themselves there!! Can you let me know on dyno and carb pricing??
(Post 4542542)
Thanks for the testing information, Smitty. I'm watching your thread closely and really appreciate what you're doing. It would be very interesting to put a 1500-1600 TB on it to see if it is a carb/fuel temperature or atomization issue.
Originally Posted by Rookie
(Post 4542642)
Rob, when do you plan on completing and dynoing? I need to finish the cad on the adapters.
Smitty, have you tried firing the injectors at different degrees before and after TDC to see where they are most efficient for your motor ?
Originally Posted by GPM
(Post 4542724)
It be interesting to see what happens to the bsfc , with changing injector timing. I assume the camshaft events can dictate a need for a change in injector timing? Id think that if the injector timing was based on say a stock cam, and you go to a bigger cam, that opens the exhaust valve sooner, and had more overlap, maybe firing the injector later, so that you arent blowing fuel out the exhaust?
Maybe not much power to be gained here, but maybe some fuel efficiency? Just thinking out my azz on this |
This efi stuff is cool chit, i cannot see how you can do all that it can do, by not getting a setup on an engine dyno. How can you do all this stuff by tuning on the water on a custom build? So much that can be tuned. Timing maps, fuel maps, injector timing, knock sensor setup, and so on.
(Post 4542752)
(Post 4542754)
(Post 4542752)
(Post 4542761)
It takes a while, it's not as easy as some of the salesmen on here claim. Some of the systems are less complicated than others, the parameters have to be set for the marine application. They can be amazing once dialed in, some may throw it in the lake before getting there. Try putting dual wideband 02s on your carb motors, they may not be working as well as you thought.
Originally Posted by hogie roll
(Post 4542814)
I've been wondering if injection timing could be used to help push more air in the cylinder. Use something kind of like a miller cycle cam with late ivc and inject when the piston is at or near bdc and the airflow has pretty much stopped. You would need large capacity injectors which could handle most of your fueling needs in a short window of time.
(Post 4542817)
Ive been running widebands on my carb engines for years
(Post 4542840)
Do you run 1 or 2 sensors
My engines bank to bank wise, have never varied more than a couple tenths. I believe that is thanks to the dual carb setups, and straight two lobe rotors. My buddy's with twisted lobes, shows a little bit more difference from bank to bank, but nothing crazy. |
(Post 4542839)
I'm guessing General Motors had some reason for putting the injectors in the cylinder head of the LS motors.
It can theoretically greatly improve economy by having localized stoich mixture only around the spark plug. But I think emissions prevent fully utilizing that strategy. |
(Post 4542851)
Currently, I have a single ngk powererdex wideband. I did have dual FAST unit prior to the NGK. On the dynos, I have used the NGK, and Daytona sensors widebands.
| All times are GMT -5. The time now is 02:48 AM. |
