-   -   Thoughts on fuel additives (https://www.offshoreonly.com/forums/general-q/346129-thoughts-fuel-additives.html)
Eliminated572 04-13-2017 08:14 PM
All this just from sitting over the winter? Throw some boostane or torco in it for added safety if you choose so, then take it easy until you dilute it out. You don't need to set the throttles to kill every damn second the boats on the water...
14 apache 04-13-2017 08:26 PM
I am with you my sea ray sat 2.5 years started up perfect ran perfect didn't even have stable. Just don't beat the flames off it if you can get some race fuel throw 20 gallons in it. Guess I'm just lucky lol
wildthing357 06-10-2017 05:50 AM
Who wants a 100 gallons of year old 93 fuel...
SB 06-15-2017 09:30 AM
Good article with test on Boostane
The Big Fuel Test: BOOSTane Adds 24-RWHP
BenPerfected 06-16-2017 09:17 AM
We generally add 20-25% 110 leaded race gas to 75-100 gal of pump gas.
speicher lane 04-01-2018 08:25 AM
Wasn't going to start a new thread as there are a few out there already.....Engine Power is on the boob tube, a sponsor is Race gas fuel concentrate and may be an option for those that need a tweak of octane but Boostane osn't on the shelf.
Never used it personally, just seen the promo on what it does / or may claim to do.... but it may be a real option from the snake oils out there.
RACE GAS | Racing Fuel Concentrate
turbo2256b 04-01-2018 10:16 AM
i have been using ACES4 it works as a booster and a stabilizer. have had vehicles sit over a year and start right up pushed hard no misfiring stumbling . no strange build up on the porcelain because of chemicals in other boosters that dont burn. also proved on dyno to boost HP. seems pricy untill you figure only 1 oz is needed per 6 gallons.
hogie roll 04-01-2018 08:06 PM
Drop some av gas in it. Should be cheaper than race gas, adding a leaded octane booster to 100LL gives it a big octane boost too.
SFOcean 04-02-2018 01:32 AM
I have been using Brian's stuff in everything for quite a few years. One boat sat idle since 2014 with 10% ethanol gas in it; started right up this year and ran OK. Ran it easy (not a supercharged engine) to burn the old fuel off. Was shocked the fuel hadn't phase seperated. Sems to work as an booster as well in the roots and twin turbo motors.
