-   -   lineup ssm3 and engines (https://www.offshoreonly.com/forums/general-q/346481-lineup-ssm3-engines.html)
leif 04-25-2017 12:17 PM
1 Attachment(s)
[ATTACH=CONFIG]566787[/ATTACH] Hi Need alittle help here..use to run bravos , but are getting into 41 apache and ssm3, trannies etc..bought everything from different people..how do I allign drive, tranny,engine correct..have 4 engine mount holes.Also do I mount tranny on engine and slide it into the
inner transom?Thanks for your input.
MILD THUNDER 04-25-2017 04:30 PM
Mount the trans onto the bellhousing, then install the engines. You are going to need a SSM alignment bar. Are you using front and rear engine plates? Or just the fronts?
leif 04-25-2017 04:56 PM
Hi front and rear..where do i get alignment bar..have only found for trs
f311fr1 04-25-2017 09:16 PM
Try Cobra in Miami
MILD THUNDER 04-25-2017 09:23 PM
Trs and ssm alignment bar is the same.
leif 04-25-2017 11:34 PM
Thanks Mild Thunder
adk61 04-26-2017 09:12 AM
the bar is the same but the puck that goes into the helmet is smaller on a SSM drive... just went thru this on the weekend with another buddy up here... he bought a TRS alignment tool thinking they're the same, and found that the locator puck doesn't go into the recv'r register in the helmet!!
adk61 04-26-2017 09:14 AM
a Quick trip to the lathe will fix that though... :angry-smiley-044:
Jamie77905 04-26-2017 09:43 AM
Does he wanna rent his bar as I will be doing the same install in my 36 Warlock Cat in the next week or so?
I'CE 04-26-2017 01:22 PM
some I have seen over the years have a stepped down puck
