-   -   96 mpi mefi 1 no fuel pump or beep (https://www.offshoreonly.com/forums/general-q/346532-96-mpi-mefi-1-no-fuel-pump-beep.html)
27victory 04-27-2017 09:04 PM
96 mpi 502 mefi 1, i have power to ecm no fuel pump or beep when turn key... Any suggestions?
Trash 04-28-2017 01:49 AM
Fuses OK?
Wiring to fuel pump ok?
27victory 04-28-2017 07:16 AM
Fuses good, wiring good, 12v to ECM nothing after, no voltage green white wire to pump. No beep when ignition is powers on
Revelocity 04-28-2017 08:12 AM
Not sure about 1996 but on 1998+ there's a fuel pump relay located near the ECM that you should check out.
Gimme Fuel 04-28-2017 09:14 AM
Dumb question.......but is your gear shifter perfectly in Neutral?
If the neutral safety switch is tripped a bit it makes the engine appear dead, non-responsive, no crank. I've been guilty of this....even to point where I get pissed and start checking fuses, relays, etc. only to find out the shifter was bumped against the switch. I have a habit of jiggling/re-centering the shift sticks every time before starting now. With my old boat that had aftermarket ECU, I got used to not worrying about it because switch was disabled, when I went back to Merc/MEFI ecu's on new boat, sure enough the neutral safety switch pissed me off at the launch ramp when one motor wouldn't fire and acted completely dead.....
27victory 04-28-2017 09:45 AM
Shifter appears to be in nuetral, engine does crank, however no beep when key turned on and no fuel pump run to prime, traced power to ecm nothing on other side
Trash 04-28-2017 11:24 AM
On a tangent to what Gimme Fuel referenced check the lanyard kill switch too.
Padraig 04-28-2017 11:56 AM
Yes the plastic forks on the kill switch lanyard get weak and while it looks like it engaged it is not fully engaged. Try holding the button in a different see if that makes a difference.
Padraig
SB 04-28-2017 12:17 PM
No power on either side of what ? What wires did you test to determine this ?
Edit in: don't need to answer above. I get it. Read what you said wrong.
SB 04-28-2017 12:34 PM
If anyone wants to look at the wiring chart, look at Pg 42 of this .pdf:
http://www.boatfix.com/merc/Servmanl/16/16C5R2.PDF
