-   -   496 efi high idle (https://www.offshoreonly.com/forums/general-q/346645-496-efi-high-idle.html)
homan 05-02-2017 09:14 PM
496 efi high idle
I have a 2003 496 efi that has a high idle especially on start up you put it in gear and it's like whoa nelly. I changed the iac valve only made a slight difference
Trash 05-02-2017 09:29 PM
It is likely a vacuum leak. Could be anything from a hose came off, cracked rubber, etc. In addition check throttle linkage for rigging.
homan 05-11-2017 09:21 PM
when I close off the hose for the IAC valve it idles down to 600 will have to research further thanks for the response
underpsi68 05-11-2017 09:39 PM
Sounds like a bad iac. I would check the connector and than remove the iac and see if it is stuck open. Also check the iac gasket.
BUP 05-12-2017 02:02 AM
easy stuff first unhook the throttle cable then start the engine - - can you manual move the throttle blades to bring down idle rpms ?
Scan the engine and look at tps and IAC. Voltage on tps and PWM % on the iac -
IAC connector on top of
TPS issues
Agree possible vacuum leak and you can detect a vac leak by reading the scan of the engine
Dirty flame arrestor
AND what about the installing of a new IAC gasket and the IAC muffler ? is yours installed - the IAC muffler ? and if so how bad is it ? or did it suck itself into the hose ?
Hopefully you installed the IAC properly and in a 3 torque pass
