-   -   SSM 3 what tranny to use (https://www.offshoreonly.com/forums/general-q/346888-ssm-3-what-tranny-use.html)
MILD THUNDER 06-08-2017 10:11 AM
A rubber mallet . That shaft is just an extension that is slid over the splines on the trans main shaft. Back when i did this swap, it took about 20 minutes removing the trs tailstick, trs coupler shaft, and installing ssm coupler shaft and tailstock.
leif 06-08-2017 11:26 AM
Ooohh I love OSO..big smile and thanks..will try that first thing in the morning..let you know..
b regards
Leif
northernoffshore 06-08-2017 11:46 AM
2 Attachment(s)
http://www.offshoreonly.com/forums/s...ine-drive.html
dereknkathy 06-08-2017 12:17 PM
stuff like that doesn't show in the manual since it wasn't TRS specific. so, one could also put these shaft extensions and housings on a shaft boat borg?
adk61 06-08-2017 12:28 PM
take the short tail off the doner trans.. including the bearing and shaft assembly, also remove same from TRS use the gasket Joe mentioned and reinstall the short (#3) tail shaft and bearing into the cover then install onto transmission... not a difficult job, just make sure splines line up and gasket surfaces are clean...
