-   -   Fuel tank size on 2007/2008 Renegade 38' Cuddy (https://www.offshoreonly.com/forums/general-q/346941-fuel-tank-size-2007-2008-renegade-38-cuddy.html)
Panacea 05-15-2017 08:45 PM
I'm trying to find info (specifically fuel tank size) on a 2008 Renegade 38' Cuddy. I'm possibly putting an offer on one, but I need to verify it carries 300gal or more for the range I need (back and forth between the Keys and Abacos). It is a different model than the current 38' since the hull length is a true 35' and it has a Stainless Marine transom bracket and not the new euro transom. The boat has two tanks, one foreward and one aft. I put several calls and an email in to Renegade, but no response.
Sweet looking hull and appears to be a good value. I'd even toy around with the idea of a new build, but...
Does anybody have this hull or any ideas where I can find some details?
Panacea 05-15-2017 08:48 PM
Here is an identical hull http://149.255.34.50/listimg/img1_03...sydo7hsT3k.jpg
Panacea 05-17-2017 08:01 AM
Bump.
Still no call or email back from Renegade. Its a pretty simple question any manufacturer should be able to answer. How much fuel does a particular boat carry in each tank? The receptionist on the phone said she would "have to have her manager give me a call back". LOL PPPPPhhhhhhhhhhhhhhhhhhh.....
Captain YARRR 05-17-2017 08:20 AM
I am pretty sure you can get a look at the tank and it will have a label on it most likely. My last two boats have had labels. I called the factory (not Renegade) on one and they actually told me the wrong information, the label was correct though.
Panacea 05-17-2017 08:35 AM
Good thinking! There are only two small 5 inch access plates on the deck. I assume for the pickups/senders. But hopefully the tank info is stamped under there. Thanks man.
