-   -   Battery issue? (https://www.offshoreonly.com/forums/general-q/347051-battery-issue.html)
splashandburn 05-21-2017 10:20 PM
Originally Posted by getrdunn (Post 4555856)
Good point. Seems odd both sides but had stranger things happen. Not sure what kinda switch you have but does it make a difference on all position or try jumper cables from battery to batttery. If your not noticing much of a diff I would have to agree with potential starter issues. Boat starters see a lot of moisture and condensation. I recently bought a battery load tester from NAPA. Can't believe I went all these years without one. As mentioned double check engine grounds from battery which I'm sure you've done already.
The switches are Perko switches. Yes it does start much better with battery switch set to ALL. I'm sure the issue is that the voltage is dropping to 9+ volts under a load but what would be causing such a drop?
dbkski 05-21-2017 11:42 PM
Reread the Duracell battery specs then buy starting batteries to start your BBC's and use the deep cycle batteries to run
your stereo.
http://www.driveduracell.com/assets/...image/1853.pdf
Sorry but your logic is Bass Ackwards.
Gimme Fuel 05-22-2017 07:44 AM
I would start by replacing the heavy leads from starter to switch and from battery to ground. Had that problem in my old checkmate, unless batteries were completely fresh, engine would crank slow and not have enough voltage to fire MEFI1 computer. Replaced the leads and made sure I had a good clean ground. Spun right up good as new. The heavy leads even while insulated will get corroded over time, especially depending how the crimps are made. The factory crimp ends can be improved by sweating some solder into the ends before you install them.
Chances are it is a failing crimp or dirty ground somewhere.
splashandburn 05-22-2017 09:13 AM
Thanks. I was thinking that was where I might start. Not looking forward to trying to get at the starter cable though. One other note - I did have to replace the onboard charger this spring. Would only put out 11.5 volts to one battery bank but that shouldn't have anything to do with what i'm experiencing now.
ALL_IN! 05-22-2017 10:38 AM
Use cranking batteries for your starter and deep cycle batteries for your house loads. Deep cycle batteries are not designed for high amperage / short duration demands as in your starter.
Blueabyss 05-22-2017 10:59 AM
First I would not call 12.7 fully charged. should be 13.2 at a minimum. I would check your charger and or alternators . Second make sure you have a ground wire coming off each battery going to the block. Not just a jumper black wire going from one neg terminal to the other neg terminal then to the block.
Chris
splashandburn 05-22-2017 11:12 AM
Boat only has room for two batteries. I've always run deep cycles and never had an issue.
MonkeySea2 05-22-2017 11:31 AM
I'm having the same issue as you. I have fresh batteries, 1 is an Interstate cranking that I bought last May, 1000 CCA. The 2nd is a Duracell AGM dual purpose, 800 CCA. I load tested both and they are good. But I get a bad hesitation when I start my 496 Mag. I'm worried that it's the started because it's hell to get to if I have to replace it. None of my cables are corroded and I use dielectric grease on the battery posts.
underpsi68 05-22-2017 11:39 AM
Dielectric grease is non conductive. I wouldn't put it on a battery post.
30ftpanther 05-22-2017 01:41 PM
https://www.w8ji.com/dielectric_grea...ive_grease.htm.
