500 EFI valve adjustment
How do I adjust the valves on a 500 EFI ? It has Crane gold roller rockers. Never had to adjust adjustable rocker arms. Have a few that were louder on one bank than the other.
Thanks |
which ever cylinder your adjusting,,bring it up to TDC,adjust by finger to 0 lash,then go 1/2 turn more.lock the allen down while holding the adjusting nut.
OK Thanks !!
compression TDC,not exhaust TDC
Originally Posted by Smitty
(Post 4556385)
Thanks If original, how many hrs ? |
run them in firing order, less crankin the crank, make sure the lifters are on the base circle of the cam when lashing
A way to be sure. Both valve covers off. 18436572. When both rockers are moving on 6, 1 is good to go. same with 8-5, 4-7, 3-2.
| All times are GMT -5. The time now is 08:30 AM. |
