Moisture in the exhaust manifold
Very long story short.
I noticed a little leak where the exhaust manifold meets the riser - just a little drip. I ordered a new gasket and today replaced it. As I was looking into the exhaust side of the manifold I noticed a little moisture on the bottom - we are not talking about a puddle of water - but very little. My thoughts were that a) the gasket was compromised and allowed a little water in or b) The last time I ran the boat it was rather cool out - no it was cold - I only ran about 10 minutes and nothing WOT and shut it down- I'm thinking that this is just condensation - Any thoughts/comments It is a 200 7.4 MPI Captains Call and Bravo 3.-- Fresh water Everything is running perfect - very solid 60 mph starts good and idles like velvet. Thanks in advance. 3pointstar |
I would say more A but potentially A and B. I doubt you have any reversion or cracks. Something to keep an eye on though. Might be worth the price of another replacement gasket and check again in a couple weeks. Otherwise pull the rubber exhaust hose off and check with borescope.
2000? 16 year old exhaust manifolds? You are in fresh water all the time, I assume. But those manifolds ain't young anymore. I have a drain hooked up on my exhausts. I can't see leaving a bunch of water above my exhaust ports all week when not using the boat.
Drained and winterized same as always. Last project boat I had was a 78 and they never had an issue. Fresh water use only.
Derek you drain your exhaust after every use?
Originally Posted by getrdunn
(Post 4557494)
I know you are getting some questions about the practice. But I did that when I first noticed the leak. A question that I always have. If it's leaking on the outside how do you know it's not leaking on the inside.
(Post 4557494)
| All times are GMT -5. The time now is 12:05 PM. |
