-   -   Procharger performance (https://www.offshoreonly.com/forums/general-q/347270-procharger-performance.html)
MILD THUNDER 07-20-2017 11:20 AM
Originally Posted by indysupra (Post 4570533)
It's port injected. No I don't see any spikes. New pulleys just arrived so I will see after that but doubtful. In a car I know it can be an issue when the boost gets higher. I know 100 deg is obtainable with other setups i was just posting it because of where I'm getting my water from ( almost engine temp water). With some testing I did with doing one motor directly from the sea strainer and the other thru the crossover it was 18 degrees cooler but was in different operating conditions. I have the fitting to change it over but don't want to change too many things at once. Also another note on iat's i know of many setups that are in excess of 130. And that in a boat is to the point of needing timing pulled.
Thats pretty good IAT without any fuel cooling in the plenum
indysupra 07-20-2017 05:54 PM
I'm thinking I'll be able to keep them at 90 deg ish when plumed to cooler water. Another good thing is the intercoolers are pretty cheap. I got both of mine for about half of one roots style intercoolers.
Baja Rooster 07-21-2017 11:39 AM
Originally Posted by articfriends (Post 4570537)
The flow curve starts out slower the bigger a procharger is, my m3sc made 900 or 950 ft lbs tq at 3500 and 890 or something like that at 3000 but it was pulleyed waaay up, i DRAG raced roots blown flat bottom vdrives from a 40mph roll from 3500 up and surprised quite a few of them with my 272 baja, fwiw, smitty
I find it a great shame that you just couldn't get that extra .5mph to hit the century mark on that baby, lol.
articfriends 07-21-2017 12:42 PM
after violently bow steering bow sideways at 96 mph when testing the imco -2 and hanging onto steering wheel with legs in air it put the fear in me, sold shorty which never worked well and ran the 1050hp pulley w 30 pitch 98% of time after that around 96 mph, lost interest in breaking that century mark!
articfriends 07-21-2017 12:48 PM
water tuned a whippled 500efi last monday for a oso member from indiana in a baja 232 , boat still had cable steering! Brought back memorys of the pre hyd steering days w my 272 back when it ran in the 70's
That little 232 was a REAL handful, ran mid 80s when we were done, told owner his next purchase should be twin ram full hys steering. Friend who bought the 272 had us put a m-3sc back on it yesterday but its on a iron headed 560hp 502 not the 548 i had. Going out to water tune that today or tommorrow, will probably run 78ish, with the big trim tabs and hyd steeringb i left on boat when i sold it that will be like a gentle cruising speed!
Baja Rooster 07-21-2017 01:43 PM
Bajas have their place in the world, it's not at the century mark. :) Kuddos for trying though! I actually took your experience into consideration in what to do, or not do on my 272.
articfriends 07-21-2017 04:10 PM
W 24"trum tabs, nose cone and full twin ram hyd steering boat was fairly solid to mid 90s, you wouldnt run those speeds in 3 footers or bad criss cross wakes by any means. I did race that 35 or 36 ft baja in pt huron that has lingenfelter 604's thru 2-3 foot criss cross waves for 8 or 10 miles a little hairy!!
indysupra 09-16-2017 09:13 PM
2 Attachment(s)
Not my final version but I made these up real quick to see how big of a difference it would make. Holy crap! Huge difference. So much easier on the boat.
MILD THUNDER 09-16-2017 09:23 PM
Mike tkach and I were talking about those for procharged setups
ICDEDPPL 09-17-2017 10:43 AM
How did those help? Please tell us more.
