oil by pass valve in 6.2 mercruiser??
Is there a oil by pass valve built into the block on a 2002 6.2 mercruiser?
Oil filter adapter (it has the bypass in it) is mounted to the blocks oil filter pad. See #11 in photo.
BTW: if you need one you can get from GM for lot less than Mercruiser. http://www.mercruiserparts.com/Merc/...OMMON/9826.gif http://image.superchevy.com/f/techni...er_adapter.jpg |
| All times are GMT -5. The time now is 03:19 PM. |
