HELP!!! 2000 7.4 mpi
hi I need the fel-pro part# for the headset and the upper intake manifold set... try to get the boat ready for the 4 july weekend help help help
17046 head gasket
Originally Posted by MichiMike
(Post 4564630)
17046 head gasket
The OP has a 2000, so should be Gen VI |
Originally Posted by SB
(Post 4564633)
I believe those are for Mark IV.
Just did a little more Diggin I've got a gen vi non-adjustable rocker
still looking for the headset part number |
Head gaskets or head set? Valve cover gaskets reuse well. Exhaust gaskets are best to get Mr. Gasket 454 header gaskets. Probly don't need valve seals. So you need head gaskets and intake set from 97 suburban with 7.4 engine from auto parts store.
you need a set of fel pro 1037 head gaskets .a lot of intake gaskets will work but i like the mr gasket #121 and a smear kote of the right stuff around the ports,like derek said you can reuse the valve cover gaskets.
Thanks guys
Just brought the boat to find out that the motor had a blown head gasket's and had to take the heads in to get machine because they're warped That's why the headset thanks guys appreciate it |
| All times are GMT -5. The time now is 05:32 AM. |
