-   -   No Spark? MSD 6m-2 box (https://www.offshoreonly.com/forums/general-q/347976-no-spark-msd-6m-2-box.html)
Blackedout02 06-27-2017 12:17 AM
So I took the boat out this weekend, started great, idled fine, went to get up on a plane, at about 3000 rpm the engine died, and wouldn't restart.. towed back, and had a look in the driveway tonight. Getting no spark at the plugs. I tested this by pulling a plug wire, throwing an old plug in, grounding it against the head, and getting no spark. Next test was the msd 6m-2 box. I did the recommended test with the screwdriver in the coil wire, near a ground , and got a healthy spark jump to my ground, by jumping the green/purple wires in the harness to the distributor. To me, that eliminated my Ignition box as the problem.. where would I look next? I've never had an issue before. Grounds are good, the boat ran great for a few weekends before this with the bed engine installed. The one thing I did test and notice tonight, was the 12v power wire for my msd box is jumped from the starter power, and that battery was only showing 12v on my mulitimeter, while my other battery was up at 12.7. It appears they forgot a jumper cable to bridge my 2 batteries. Would the battery being at 12v be the cause of this ignition issue?
fbc25el 06-27-2017 08:10 AM
I don't think 12 volts would be a problem. The heavy red& black wires should go to the battery. Check the pick up coil in the dist.
mike tkach 06-27-2017 08:25 AM
i agree.
benjen 06-27-2017 09:32 AM
You said the grounds are good. Are you assuming that or did you actually remove them and clean the contact surfaces?
Blackedout02 06-27-2017 10:20 AM
i tested the ohms on the harness coming out of the distributor and am getting 590 as msd says I should , which SHOULD eliminate that problem as well...
Blackedout02 06-27-2017 10:42 AM
yes. Checked and cleaned grounds.
SB 06-27-2017 10:50 AM
For schits and gigles, fully charge that battery and try again. Even though I have ran MSD's on vehicles without alternators down to 10 volts or so, I do know MSD's can be cranky pants and do some weird things.
SC288 06-27-2017 03:22 PM
I chased all sorts of problems with mine last Summer and followed MSD's trouble shooting tips etc. We thought it was a bad battery, bad coil, bad ground, alternator, ignition switch....ended up being the box after all. It was odd as it would act up some days and not others so it was difficult to diagnose. As many will tell you it is not a bad idea to carry a spare and before wasting all Summer may be worth it to swap it out.
SB 06-27-2017 04:57 PM
MSD's should come with Sea Tow membership.
ROB FREEMAN 06-27-2017 05:03 PM
Got two crane boxes I swapped out for my Daytona boxes . Work perfect. Wanted the added benefits of the daytonas. But fell short on the downloading. Ended up a 750 he programmed curve. Waste of money .. but maybe down the road.
SB 06-27-2017 05:12 PM
Understand this^^^
Don't understand this ^^^. Ayuh, Maybe it's my northern NE accent. :)
Blackedout02 06-28-2017 02:24 PM
Well, it turned out the dist gear had a cpl teeth sheared off.. back to the builder it goes 🙄
fbc25el 06-28-2017 03:14 PM
That Sucks !
ROB FREEMAN 06-28-2017 06:43 PM
Originally Posted by SB (Post 4565017)
Understand this^^^
na probly just me .. have nice nite .. when you guys get sick of msd ... get a good reliable box ..like crane box or Daytona . witch basically a new version of the hi ball 6 crane box I was refuring to ..
