-   -   496 ect problem? (https://www.offshoreonly.com/forums/general-q/347996-496-ect-problem.html)
actionmarineguy 06-27-2017 12:59 PM
496 ect problem?
exhaust coolant temp sender went bad. when went to change it was a plastic sensor threaded into man it broke off with verry little effort. has to be drilled out. ( The Question is are the pieces that will fall into manifold plastic or metal)
class6 06-27-2017 02:32 PM
Brass, and what falls in I doubt you could get it out if you tried. I wouldn't worry Just keep grease on the bit to catch the chips
