Causes of prop slip?
Decided to take one last trip out tody before the winter layup. I hadn't been back in the water since I changed out the valves and the carb so today's short journey would also be a test of sorts to see how she was running after being torn down to the short block.
The 383 ran well and with my cheapo-SS 21" prop I was able to turn 5200 RPM at WOT (I believe that max timing was set at 30*... TADA... no audible detonation; could probably use some more timing though). I think there are some funny things going on with the cam (as in it's probably way advanced {according to coversations with the builder}... going to fix that over the winter) so there maybe some more left in it that I haven't quite gotten to yet. The engine was very responsive though and I attribute that to the Holley carb. I still have a squirter/pump issue to work on but it still did very well. Now for the topic... I ran my speed through BAM's prop slip calculator and got (speed was 50 MPH... lost some speed... probably needs some more timing) 38% slip. How and why is what I want to know as well as how to fix it. I'd really like to see slip in the 10-15% range. Is it just the old prop? If I'm able to run a Mirage 3-blade 17P within that range, does that mean that I can run a Mirage 21P and expect the same slip? BTW... I had one of those fin-thingies on the drive... gone now. The boat handles and moves so much better. Thanks! |
If you haven't already, I would get another tach wired up to check the factory one. Is the hull clean? What kind of prop and how heavy is the boat.
I once tried a Laser II at my friends urging and the thing slipped like mad compared to a mirage +. Didn't compute the slip, but didn't have to .........It was obvious. Could rev the motor at 4k at will. Didn't bother to check top end. The props don't look much different. |
Bottom is/was clean (it never ever stays in the water). Prop is an older dog-ear Quicksilver 21P (closest thing to it is a Renegade I believe... I think that's what the P/N crosses to). Boat weight I would have to guestimate at 4600 lbs... tops.
The hull is not a performance design but is basically the same as a 4Winns Liberator... only mine has a different cap. I've checked out the tach already. Though it's a little slow to react, it is accurate. I already have a 17P large diameter Mirage, but I think the pitch is way too low. I put the 17 back on it earlier in the season because I couldn't turn the 21 for some reason. Well now I don't have that problem based on the RPM I was able to get out of it yesterday (with it still not being in proper tune). If I could get the prop to bite more I think I'd get to 60, which right now is the Holy Grail for my configuration (after all, it is a family boat. ;) ). I know the old gil has it in her, I guess I need to find the right prop to get there. Now how do I correct it? |
Get a couple of known reference props, like a mirage and a bravo, at that weight. That buddy of mine that bragged so much about the Laser was shocked at the result of a mirage. After switching over to one, he said his boat was faster at a much lower rpm and felt "hooked up". That's the definition of slip.....or lack of.
I posted the same question over on BoaterEd.com...
More than likely, the huge amount of slip is being caused by a lack of blade surface area and/or small diameter (the 21P is noticeably smaller than the 17P Mirage). I guess I'll be testing some props next season... among other things. |
i had a 211 liberator with a 350. went 52mph on gps at 4800. perfect setup for the smallblock. the prop was a 21 pitch quicksilver with diameter = ???
there's a reference for you. with 5200 and my prop, you should see chang/bing/blonk..petoooy = 56.3 mph. since you have more power than my 260hp did, and if you can pull a 23pitch to 5,000 then you might see....... just under 60........ just for reference. it was a 1.5 ratio drive. you do have the SAME drive don't you......as before....... good luck. |
| All times are GMT -5. The time now is 06:09 AM. |
