-   -   Gauges? (https://www.offshoreonly.com/forums/general-q/34844-gauges.html)
88 MACH 1 10-14-2002 05:46 PM
Gauges?
Been looking for new gauges. How important is an oil temp gauge? I'm looking for white faced gauges and all that I have found don't offer the oil temp gauge. Anyone know of a company that sells them? Thanks in advance, 88Mach 1
bajadude 10-14-2002 05:53 PM
IMHO oil temp is very important especially if you're running a performance motor. I've had boats with 7.4, 454 MPI and 496 and none of them had an oil temp gauge. With my HP500s, its a must. Have you looked ay Gaffrigs yet?
What are you running?
later 10-14-2002 05:55 PM
oil temp can tell you if you got something not right before you really tear something up are get stranded
88 MACH 1 10-14-2002 06:29 PM
bajadude
I'm running a 454 with 500 hp. An all roller set up. I really want white faced gauges. I'll check out Gaffrigs. Do they have a web site? Thanks, 88 Mach 1
bajadude 10-14-2002 06:44 PM
Here's the site Livorsi (Livorsi is Gaffrig)
You can also get them (cheaper) through Nisonger Marine, Teague
and most of the other distributors
Hope this helps
ursus 10-15-2002 08:06 AM
Oil temp is probably the most important guage, it tells you when there "is" a problem, water temp tells you when there "was" a problem,, water temp is still necessary tho don't eliminate int
