-   -   Valve Springs/Winter Storage (https://www.offshoreonly.com/forums/general-q/34952-valve-springs-winter-storage.html)
rws 10-15-2002 07:43 PM
How many of you Guys take the valve covers off and back off the rocker arms? I have a .625 lift cam in My small block with about 450 lbs at open.
Rob
Panther 10-15-2002 07:59 PM
Won't Hurt
It won't hurt to do it, that is if you have the time?
I am doing mine this year. It makes sense for me since I have a solid cam, and would need to adjust everything in the spring anyway.
traviss 10-15-2002 08:02 PM
We just pull the motors and do rebuilds its alot faster then removing the valve covers and doing that work :D :D
HPJunkie 10-15-2002 10:30 PM
Traviss your right its a sickness. Gimmee just 1 or 2 more to brag about! Really if you can its good to back off the springs, although I've heard you can crank it a little every once and a while as if your "using" it so the springs dont take a set. Greg
Crazyhorse 10-17-2002 11:59 AM
I'd pull the covers and back them off. Not only does it save the springs but closes off the cylinders.
KAAMA 10-17-2002 05:19 PM
And make sure you fog the cylinders well before you do. Actually, the cylinders should be fogged whether you back the rocker arms off or not. There is a fogging agent available in an airsole can that sticks to the cylinder walls and coats things better than just using tranny fluid. I can't remember the name, but usually a marine type store will carry it.
