-   -   502 Pro charger with closed cooling (https://www.offshoreonly.com/forums/general-q/349547-502-pro-charger-closed-cooling.html)
oopee 08-31-2017 04:25 AM
Hi,
i would like to know is there any restrictions to use closed cooling with pro charger setup? I have understand that many setups use crossover so I would like to know is there some restrictions for closed cooling (..like placement of water circ. pump or something like that)???
Does electrical circulation pump have enough flow for marine cooling?
ezstriper 08-31-2017 08:49 AM
procharged engines like to run very cold so no t-stat, you are going to have to tap in before the heat exchanger to flow water to intercooler, the engine pump should be fine
Baja Rooster 08-31-2017 08:02 PM
Maybe this will be of help?
http://www.offshoreonly.com/forums/d...iners-etc.html
