-   -   Help, Bravo has too much side to side play (https://www.offshoreonly.com/forums/general-q/34962-help-bravo-has-too-much-side-side-play.html)
Waveline24 10-15-2002 11:23 PM
have noticed that the outdrive is sloppy when you are standing behind the boat or when in the water. You can move it side to side quite a bit before it hits the point where stops and forces the steering wheel to turn. What part is it that needs to be replaced or adjusted to correct this. I hope this is enough info for you to understand my problem. It just seems too sloppy. It works just fine as far as the mechanical running aspects.
What do you think?
Let me know if you need more info.
Audiofn 10-15-2002 11:36 PM
Sounds to me like the tiller arm is loose. If you have some funky tools you can tighten it in the boat and see if that works. If not you have to get a kit from Mercury. What you do basically is law the template on the side of the transome assembly outside the boat and drill two holes in either side. Then you will have access to the bolt that tightens the tiller arm and you can retorque it. If the tightening does not work then you will have to replace the pin and tiller. This is a lot more involved.
Jon
HARRISONMIRAGE 10-16-2002 12:25 AM
CHECK THE SQUARE TANG OF THE STEERING PIN IN THE GIMBAL.YOU CAN TIGHTEN THE U BOLT(TOP OF GIMBAL RING)TO GET MORE SQUEEZE ON THE TANG.MERC RECOMENDS DOING THIS EVERY 50 HOURS.THE STRESS ON THIS AREA IS WORSENED BY HIGH HP ROUGH WATER USE.I WOUD REMOVE THE NUTS AND RUN A TAP THROUGH THEM,WIRE BRUSH THE U-BOLT THREAD,AND GREASE THE NUT BEFORE RETIGHTENING THE NUTS.I KNOW OF PEOPLE BREAKING THE U BOLT FROM THE NUT BEING SIEZED ON THE U-BOLT.DO NOT BREAK THE U-BOLT OR YOU WILL BE HATING LIFE.I HAD THE SAME PLAY IN MY 257 MIRAGE AND THOUGHT THE PARTS WERE WORN, BUT AFTER CLEANING THE THREADS AS STATED ABOVE I COULD NOT BELIEVE HOW EASY IT WAS TO REMOVE THE PLAY.AS IT TURNED OUT I HAD TO CHANGE THE STEERING PIN DUE TO A LEAKY STEERING PIN SEAL.NOT A FUN JOB EVEN WITH ENGINE OUT. PS GET YOUR ASS UP TO THE HARRISON LAKE POKER RUN NEXT YEAR.ITS ABOUT A THREE HOUR DRIVE FOR YOU.
Waveline24 10-16-2002 01:05 AM
Do you have any recommendations for torque on these nuts? I sure hope this is it, that would be super.
HARRISONMIRAGE 10-16-2002 01:16 AM
JUST LOOKED IN THE MANUAL. 40LB.FT. IT ALSO SAYS TO RETORQUE ONCE A YEAR OR EVERY HUNDRED HOURS.I ALWAYS TIGHTEN MINE WHEN I PULL THE LEG OR WHEN PLAY IS DETECTED.DON'T RUN WITH IT LOOSE OR YOU WILL WEAR THE GIMBAL AND PIN OUT.I JUST USE A WRENCH.YOU CAN FEAL IF ITS TIGHTENING.IF ITS CORRODED IT WONT BE SMOOTH.
Waveline24 10-16-2002 01:20 AM
Wow,
Thanks for the fast reply. I found this TSB on the web. This is what you are talking about right? I'll give it a shot.
Merc TSB RE:Gimbal
Thanks much
Waveline24 10-16-2002 11:30 AM
Jeff,
Correct on the power assist. But, my problem lies in play at the outside of the outdrive system. when you move the outdrive side to side, it has the "play" before you even move it far enough to make the inner portion (steering lever) move. This inner portion is connected to the P/S ram. This play is all outside.
ragtop409 10-16-2002 02:21 PM
wave 24
The nuts on that U-bolt are just brass with a nylon lock take them off clean the U-bolt threads and replace the nuts with stainless ones. I broke one of the brass ones retorking it this spring. Charlie
Rambunctious 10-17-2002 10:32 AM
Harrison....
can you do this without the "fix" kit drilling the clearance holes to acess the ubolt and nuts, or did you drill the holes in the drive housing.
ie. can you get at it with an installed engine from the engine bay?
I have twin 1988 bravos with some slop, but if merc calls for maintenance every year. i better figure out how. also, i don't yet have a tie bar.....
Waveline24 10-17-2002 11:46 AM
Correct me if I am wrong but the merc kit you are talking about has you drill 2 holes on the housing on the back of the boat, then you can get to some bolts to replace the ring in the gimbal.
This is the only alternative if your gimbal wont tighthen up with the two nuts at the top of the gimbal.
I am hoping I can pull those nuts and clean the threads and replace them with stainless as I am told they are brass and get it tighten er up nice.
Am I right?
