-   -   Best power pump gas cam with good dock manners (https://www.offshoreonly.com/forums/general-q/349636-best-power-pump-gas-cam-good-dock-manners.html)
Warship2k15 09-05-2017 07:59 PM
Ok I'm tired of my solid lifter cam when at the dock or in no wake zones so I thought I would ask the experts what is a good recommendation for a cam that has decent dock manners and still provides lots of power.
My setup currently is a Merlin big block chevy with ported Merlin heads.(its said to be 540 cubic inches but i havent verified it)
it's pump gas at 9.5 to 10 to 1 compression.
Victor intake with AEM 950hp carb.
GIL dry exhaust.
full roller valvetrain and solid roller lifter Crane cam
cam specs are load lift is .4167 inches resulting in a gross valve lift of .708 inches with the standard 1.7-1 rocket arm ratio.
Advertised duration is 300 degrees intake, 310 degrees exhaust at .0195 inches tappit lift. The duration at .050 inches tappit lift is 262 degrees intake, 272 degrees exhaust. Lobe separation is 110 degrees
engine is in a 25 foot cougar mtr tunnel hull
What cam would you suggest??
vintage chromoly 09-05-2017 08:16 PM
Yikes.
That doesn't sound like a cam for use with 9.5:1 compression.
dereknkathy 09-05-2017 08:37 PM
Sounds like a good cam for et's in the mid 10 second range.
Tinkerer 09-05-2017 08:45 PM
HOLLEY EFI
Mine idles great and goes in and out of gear without hardly a stumble.
598 CI, 8.6 CR
Big solid roller cam. .74 lift I forget the duration.
getrdunn 09-05-2017 09:26 PM
What is your peak rpm - hp at when fully trimmed.
mike tkach 09-05-2017 10:01 PM
i would remove that cam and go with a hyd roller setup,crane 168741 would work or call bob madera and see what he thinks.it,s ok,my shields are up.
Tinkerer 09-05-2017 10:06 PM
741 cam is pretty mild for a 540.
I had that cam in a 509 and thought it needed more.
Warship2k15 09-06-2017 04:38 AM
Originally Posted by Tinkerer (Post 4580745)
HOLLEY EFI
598 CI, 8.6 CR
Which Holley efi are you using??
Also did you lock the tune or are you using the O2 sensor?
Warship2k15 09-06-2017 04:44 AM
Originally Posted by vintage chromoly (Post 4580738)
Yikes.
I would happen to agree.Which is probably why it doesn't idle very well bellow 1100 to 1200 rpm and stalls when putting in and out of gear unless you pump the throttle when it starts to die.
Warship2k15 09-06-2017 05:32 AM
Haven't got it that high yet.
so far 5700 rpm.
but it wasn't full throttle.
Conditions haven't been good enough to go faster then the 80mph range.
GPS says I'm going roughly 86 mph at that time.
Thinking she will top out at about 6300 to 6500 rpm but that is just a guess at this point in time.
