-   -   what is the max stroke can be used in std 454 block? (https://www.offshoreonly.com/forums/general-q/34966-what-max-stroke-can-used-std-454-block.html)
timucin 10-16-2002 06:27 AM
any idea?
Cord 10-16-2002 08:05 AM
I think it's 4.5"-but that's with some serious clearancing.
KAAMA 10-16-2002 08:47 AM
The most I have ever heard is 4.25" in a standard 454 block. If you bore them .060" over and add a 4.25" crank you'll get 496 cubes which from what I understand is the most one can safely/reliably go on that block.
Pure Energy 10-16-2002 11:26 AM
Hot Rod magazine has a special issue out going into detail about stroking.
dyno 10-16-2002 12:11 PM
at 4.25 how much machine work is needed ???????
Cord 10-16-2002 12:16 PM
I believe that 4.25" only requires some minor clearancing of the bore and pan rail for the rod bolts. I believe that they will clear the cam ok.
turbo2256 10-16-2002 12:29 PM
Depends on the crank you find or purchase. One supplier said a bit of trimming would be necessary in the oil pan area... we ended up having to grind about 1/4" off the counter weights... talk about pissed.
pachangalpina 10-16-2002 01:25 PM
I recently did a 496 and only had to clearance at 1 point just above the pan rail because it was close but not touching. MkIV block, 4.25 steel crank and 6.385 billet rods. I believe that the billet rods are what allowed to get away from having to clearance the block.
timucin 10-16-2002 03:16 PM
thnx all
I get it as 4.25 max.
is it also same for first gen 502? 4.25 max stroke?
razor1115 10-17-2002 11:39 AM
I put a 4.25 stroke crank in a 502 with NO clearancing/grinding
:cool:
