Duel cooler bellhousing, paint or no
I am thinking about sealing my bellhousings where coolers are placed in. seams everyone I see they are corroded, can I paint the aluminum inside or not. does it peal or flake off. Even Hardin Marine bellhousing not painted where cooler goes, even the cover is not painted on the inside.
Your thoughts are welcome/ B38 |
only thing thats gonna last is a mil spec type hard anodizing.
If it is prepped well, epoxy holds up pretty well in fresh water.
Originally Posted by sutphen 30
(Post 4586105)
New ones mebbe the finish will hold up. Recoating the inside of the coolers? Hell no. Strip all remaining finish. It is gonna be full of oil. It ain't gonna rust...
The bell housing holds water. The oil cooler in the bell housing holds oil.
Yes, I'm talking about water cooling jacket. Not oil cooler. 😎
I wish I could do the entire motor inside so corrosion doesn't start ever. pipe dream maybe. |
Originally Posted by B38
(Post 4586325)
No currently turn key with B38.
building new mills and using new used dual cooler race bellhousings. closed cooling does not include heat exchanger or oil coolers. |
hope you faired the storms ok, my daughter is in Cozumel as we speak and the ship is being rerouted to stay ahead of the current storm, be safe
Another thought is powder coat. You can purchase those kits on eBay right around 100.00. In that small of an area a heat gun will work just as good as an oven. Problem is you'll find yourself powder coating everything especially when you get a hold of some merc blue.
Powder coat, I thought that was electrically apply. Will that process be as good.
What storm, nothing compares to a hurricane. Lol All is well done south. |
(Post 4586340)
Ls1, I stand corrected. Older models are not coated. Looks like now they are making them to last.
my current cooler covers are from Hardin, 8 plate, and 13 plate are not coated. My stuff is is older so no hard coat. |
(Post 4586340)
What storm, nothing compares to a hurricane. Lol All is well done south. Extremely simple. |
1 Attachment(s)
Wow, OK, I'm sold on the Eastwood powder coating system. Thanks all for the tips.
| All times are GMT -5. The time now is 03:11 AM. |
