525 crank sensor >
525 crank sensor
525 crank sensor
Old 10-06-2017, 06:41 AM
F-2 Speedy's Avatar
Received 3,047 Likes on 1,357 Posts
Default 525 crank sensor
is this the correct part # 828358 2
thanks
F-2 Speedy is offline
Old 10-06-2017, 07:19 AM
my book shows 864297 T01 what motor serial#
class6 is offline
Old 10-06-2017, 07:29 AM
F-2 Speedy's Avatar
that's long gone, it has a block of aluminum that bolts on a stud that it mounts to, it has 2 small machine screws that hold it in place
Old 10-06-2017, 07:57 AM
F-2 Speedy's Avatar
found it, 8283582..........will this cross to an auto part ??
Old 10-06-2017, 10:44 AM
Speedy,
Check out post 4.
http://www.offshoreonly.com/forums/d...ft-sensor.html
EDIT: It dose not look right. Ill keep searching
92nsx is offline
Old 10-06-2017, 10:49 AM
F-2 Speedy's Avatar
All those mount differently ^^^^
Old 10-06-2017, 11:48 AM
Received 4,293 Likes on 1,239 Posts
NIB Mercury 90- 275 HP DFI & Verado Sensor Crank Position 8283582 8M0030022 | eBay
https://www.amazon.com/Sensor-Positi...sition+8283582
You need it fast?
ICDEDPPL is offline
Old 10-06-2017, 11:53 AM
F-2 Speedy's Avatar
not really, guess they use the same ones on OB's
thanks
