-   -   Sealant (https://www.offshoreonly.com/forums/general-q/350190-sealant.html)
fordf350 10-07-2017 09:38 AM
Sealant
While the engines were out for maintenance I am replacing the indicator cables to the outdrives. What is the sealant used under the covers where the cables go thru the stern? Its black if that helps. Thanks
Pismo10 10-10-2017 03:04 PM
black 4200
Griff 10-11-2017 01:07 AM
Its probably just marine grade black silicone sealant.
dereknkathy 10-11-2017 02:15 AM
Indicator cables? The wires going thru transom assy? They also are in a rubber grommet. I would look into getting a new one of those. It is barely above the waterline. Also, you need wire that can handle that environment. It looks like a cord off a lamp, but it is not...
Griff 10-11-2017 12:45 PM
He's talking about mechanical trim indicator cables with the clam shell cover.
dereknkathy 10-12-2017 01:35 PM
Then they are well above waterline and whichever permanent sillycone closest matches the hull color.
