Gauge Needle Fade >
Gauge Needle Fade
Gauge Needle Fade
Old 10-12-2017, 08:37 AM
Default Gauge Needle Fade
I'm getting ready to replace all the gauges in the Scarab. I've owned Livorsi in the past and have been disappointed in how fast the orange needles fade out. Basically in 3 summers in northern Michigan, they all needed to be refaced, and the boat is covered most of the time. So the only other real option is Autometer. Who here has used them, and what has your experience been with needle fade, with the orange needles? If I go with the carbon version, they have polished metal needles so, they will be fine, but I'm not positive that is the route I want to go.
endeavour32 is offline
Old 10-12-2017, 09:31 AM
Were doomed!
Wally's Avatar
The orange Autometer needles will fade from the sun just the same...buddy had them on his boat.....i just throw a towel over the dash when we are not boating to keep it out of the sun as much as possible.
-Wally
Wally is offline
Old 10-12-2017, 10:05 AM
The paint they use on the needles from over in ching chang land is junk I'm sure.
Time to go carbon !
TooLateVTEC is offline
Old 10-12-2017, 10:23 AM
have a cover made and keep dash covered when not running
ezstriper is offline
Old 10-12-2017, 03:15 PM
I've done the towel trick, but it gets old and IMO you shouldn't have to do that on a set of high-end gauges. I used to work for PPG and I know they make paint that would hold up. I've talked to Fred at Livorsi about using a UV protected lens, which they have no intention on doing. I've also talked with a friend of mine that does plastic injection molding, and he said they could produce a needle that wouldn't fade. I just find it outrageous that it's possible to solve this issue for a few dollars, yet they are not willing to do that. Looks like I'll be going with the Autometer Carbon and metal needle option, I'm done throwing a towel over my gauges. Thanks for the input guys!
Old 10-12-2017, 03:20 PM
A good argument to tint the windshield on my 272. I was going to go with Autometer just because of the stories of the Livorsi units fading, but I guess that's irrelevant.
Baja Rooster is offline
Old 10-12-2017, 03:27 PM
Livorsi gauges will fade noticeably in two seasons, which equates to maybe 20 days in the sun for me. The rest of the time, my boat sat under a full cover and the gauges got ZERO sun. For what these things cost from Livorsi, they should use quality parts. It's not just the needle that will fade. My last set I had, the silver carbon started to yellow. How is it that my 30 year old gauges in my Scarab still look pretty good. Think about it, you can get UV protected sunglasses for $10, yet a $70 gauge has just a generic plastic lens? Unacceptable! If you're spending the money, buy the carbon Autometer gauges, IMO it's the only option.
AmiableDave (01-21-2024), Baja Rooster (10-12-2017)
Old 10-12-2017, 07:44 PM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
UV protectant acrylic clear coat on the lenses? That should help.
Rookie is offline
Old 10-12-2017, 07:54 PM
Thought I read somewhere that Autometer manufactures Livorsi gauges, or do I have company names mixed up?
Powerquest230 is offline
Old 10-13-2017, 01:27 AM
Livorsi and Gaffrig are the same, I know that. I'm not sure about Autometer making Livorsi, it is possible though. Gaffrig and Livorsi are both in Greys Lake, IL and Autometer is in Sycamore, IL. All are within 20 miles of each other, so you may be right!
