Are MEFI 1 Marine and Auto Units Swappable?
Engine's are '96 MerCruiser 7.4 LX Mpi's. I'm having erratic idling issues as discussed in this thread Help Chasing Erratic Idle Please
I ATTEMPTED to swap the ECU's today and happened upon MEFI 1's with two different Model numbers, #16234539 and #16189069. See attached picture, they are different sizes. I stopped right there as I'm not sure whether or not they are swap-able. The #162 was used by Mercruiser the #161 was not and seems to be a GM car/truck ECU (see attached picture from MEFI Burn). So now I have more questions than answers.
Should the Non-Mercruiser unit (#161) even be on a boat? Did modifications to sensors, harness, tune etc. need to be made to use in on my marine engine? I was afraid of swapping them and potentially cause more harm than good.
https://uniim1.shutterfly.com/ng/ser...714842/enhance
https://uniim1.shutterfly.com/ng/ser...714862/enhance
Thanks for any insight you can lend.
Keith
Keith
Atleast I now know I can swap side to side and see if my issue goes away.
Keith
To answer the above and for the archives, I called MEFI Burn today with the issue. They stated any of the model numbers listed in the picture in post #1 will work but as Derek eluded to they must have the correct tune installed. MB also stated the MEFI's were used in other platforms other than the marine industry. If I have purchase another unit I'll need to ensure its loaded with the proper mapping for my engine, no matter what the model number.
Keith
Keith
