Originally Posted by sutphen 30
(Post 4590834)
is the leak seen?is it coming from Hi or low?only other intrusion spot would be the trim ram manifold gaskets.
https://i.imgur.com/YVARKjR.jpg |
I'd be inclined to replace the neoprene gasket and use 4200 around the out part of the gimble.that should seal it good.
If the transom assy’s are on the boat, bolt on the drives, plug the sea pump inlet hose and head to the nearest boat ramp and back it in and take a look
Originally Posted by JaayTeee
(Post 4590867)
Did you straight edge the exterior transom mounting area top, both sides and bottom to see if there is gaps - Merc spec is max 1/16 inch of a gap allowed. And the Inner mounting transom area is 1/8 inch allowed for any gaps using the straight edge method
Originally Posted by BUP
(Post 4590899)
I'm chasing one too so subscribing to see what you wind up finding. Mine's on the lower RHS of the ring about 2" up from the bottom (when looking aft at the transom wall from the inside of the engine room), bravo 1. Can see it trickling in when dunking on the ramp, then filled the bilge and saw it weeping out. Sealed the ring on the outside with 4200 and still have the issue. Mechanic who was with me says bellows all look good. I'll let you know if I find anything as well, we're in this together.
I was chasing a leak all summer. Mine ended up being the top steering pivot. (Mine is an Alpha one though).
Originally Posted by Tractionless
(Post 4591102)
If you filled the boat up and its weeping out the main seal. I’d say you have the following: 1. Rotten transom that’s caused the main seal to lose squeeze 2. Bad seal (i.e. shrunken, dried out, etc) 3. Corrosion on main plate that’s allowing water in around the seal i would think adding 4200 would seal it temporarily but think getting to the root cause is paramount. If it were me. I’d pull it apart and see what i have. Sadly in my case...transom is solid as can be as shown in pics. Zero corrosion on transom assemblies. They are mint. And the main seal is brand new 2 months old. Not sure what i have going on. |
Originally Posted by 87MirageIntruder
(Post 4591138)
| All times are GMT -5. The time now is 04:22 PM. |
