Converting 502 to a carb need help
#31
I did this with a 94 454 mag , was able to use the old harness just went thru and removed efi connections . The fuel pump runs with the org. pump wire and I used a dui dist. ..... I recall making up wire for the alt. to battery , mines mounted low on port side. Its been over ten years ago so not fresh but still have the boat
#32
If you buy a dual plane get a performer rpm, in recent dyno testing i did it had the least amount of afr difference from hot to rich vs a std performer (#3 was 5 points leaner at wot than #2 w std performer), smitty
