Just wanted to make note I'm not certain timing events are the same for gen VI cam 169651 as one listed above. One above is 139651 non step nose. I would imagine they are but...
Originally Posted by getrdunn
(Post 4592556)
Been around for many years but stil a great cam and I bet would work well with your current build / heads. I'm not sure what your plan is to do but thought I'd post the cam card anyway.
still is going to have to prop the boat for 4800-5000 rpm. And both the numbers have the exact same timing events just one is a step nose and the other is not. |
sent you a pm
(Post 4592560)
Originally Posted by Warship2k15
(Post 4592584)
That would be a good cam for his application if it wont revert.
Originally Posted by mike tkach
(Post 4592595)
same cam except for nose.
(Post 4592584)
(Post 4592608)
I assumed they were but you know what assumption can be remember? The mother of all fk ups. Mike you've used the 651 in several builds. What's typical peak hp in a 540 +/-? Also is there known reversion issues with wet exhaust. I wouldn't think it would but I'm not certain as I've never used it.
And yes please educate us on if it will revert. |
i never used a 651 in a n/a engine but in my blown 548s if i remember correctly they peaked around 6400 rpm.
i think the torque curve was pretty flat,they made good torque from 4000 on up.i am to lazy to go to the shop to look at the dyno sheets,also i was not worried about reversion due to dry exhaust.
You don't prop to peak torque if that's what your refeering to... well you can but will be a total turd.
| All times are GMT -5. The time now is 01:30 PM. |
