CNP mounting bracket
I am thinking on going coil near plug. I have the HOLLEY EFI system.
Does anyone make a mounting bracket that I can mount to my valve covers? OR should I just make a mount that I can install on the back of the engine that will hold the coils and the computer and the normal other stuff??? |
I made 8 individual brackets that mounted with spacers and longer exhaust header/manifold bolts for my 548. Kept the coils below the manifold mostly out of sight and also allowed me to use standard truck short plug wires.
Originally Posted by Gimme Fuel
(Post 4594289)
Do you have any pictures?
Originally Posted by getrdunn
(Post 4594306)
Did u end up selling that engine? If I remember right u made great power with that build. 730??? Going by memory.
Originally Posted by Tinkerer
(Post 4594415)
I guess the stock GM truck valve cover mount is suboptimal since wires have to go right over the exhausts.
Originally Posted by dereknkathy
(Post 4594537)
Could I just build a plate to mount all of the coils and computer vertically off the back of the engine?
OR would the longer not equal length plug wires cause a problem. |
I am running JESEL shaft rockers but have a high lift cam (3/4 inch) would stock valve covers fit without spacers?
| All times are GMT -5. The time now is 03:06 AM. |
