Drives won't trim in
Hey guys. I was trying a search on this, but couldn't come up with the exact issue. Both drives (was just one, but as of this season the port is starting with this issue) will trim out,but to trim in I need to use the force of the prop right before I come off plane to get the drives to trim back in. I was going to replace or rebuild the rams as they do not sag or shift while underway. Is there anything else I should check first or does this seem to be the trim cylinders seizing up? Since I'm going to be trailering again and not on a lift, I will need to make sure I will be able to get the drives in the water.
Is the trim pump making noise when you try to trim in.
If it is then check the lines on the cylinders.To see if they are broken or leaking. If not then check to make sure the power is getting to the pump when the button is pressed and that you have a good ground. |
Originally Posted by Warship2k15
(Post 4597708)
I would replace the trim lines from the cylinders to gimble area.Then bleed them and try it.
you have nothing to lose since you should replace them periodically anyways.And 90 percent of the time its them. |
DO they have some how to's on how to bleed those lines? It will be my first go at this.
Have you ever checked the filter screens in the pumps to see if something is going bad. Also lines could be sucking air if loose. a hydraulic line can suck air and not leak fluid. are your pumps mounted level or on a angle as in transom or firewall.
Originally Posted by class6
(Post 4597840)
Try adding some oil
Originally Posted by kvogt
(Post 4597849)
Try adding some oil
Oil level is why I asked how level the pumps are mounted. Either way if they are tilted forward or back you could be sucking air into the line while running in choppy waters. I have to run mine over full with puketanks even though they are level just to keep from sucking air. Mainly on my tab pumps I'm always adjusting. And I run really thin oil in them to speed reaction time up
| All times are GMT -5. The time now is 06:11 AM. |
