Merc 280 K-Planes
The dimensions of the 280 as per web diagram is;
Wide- 14" Length- 19.25' Tip- 9" What I need to know is the length from the transom to the point where the inside angle starts, that goes to the tip. Another words, the length from the transom to the point of intersecting lines. This way I can make a template and see if the planes will fit without interference. Thank you very much for your time. David.......... |
I'll measure mine when I ger home tonight if no one responds by than.
Just checked.........6" off the transom.
Griff, 6" of the transom, At that point the angle begins that goes to the Tip. Is that correct?
Thank you for your time......Happy New Year. UNDERPSI68...Thank you for getting back.. |
If I understand your question - would nt transom width play into your question as well - inwhich you need to be asking another exact same boat owner as yours . Maybe I am over looking your question from post 1 and totally miss what exactly you are asking.
Your 292 has twin engines correct ? and how are you mounting the tabs ? following the transom line or mounting them straight across horizontal ? |
Originally Posted by AmiableDave
(Post 4602486)
BUP
If I understand your question - would nt transom width play into your question as well - in which you need to be asking another exact same boat owner as yours . Your 292 has twin engines correct ? and how are you mounting the tabs ? following the transom line or mounting them straight across horizontal ? Griff, Thank you again... Ask twice, cut once............. |
And in case you don't see the link in the link above...
https://www.offshoreonly.com/forums/...-my-292-a.html |
Thank you Knot 4 Me
| All times are GMT -5. The time now is 11:14 PM. |
