632" Crank & Rods , opinions and reviews wanted
Wanting to build a 632 NA , whos crank rods and pistons do I use ? I could go the super high end stuff , but couldnt afford the rest of the engine! . What has everyone used successfully ?
Manley , Scat , Eagle , Molnar , Dart , Lunati , K1 . I think the vast majority is offshore stuff , but not positive. Looking to go with a 4.600 X 4.750 , and a 6.535 rod to keep the compression down below 9.5-9.7 . Will have to have a 20cc dish to also help with compression . Will have a Dart Block 10.200 deck . |
I have been using Ohio Crankshaft's cranks and rods lately and have been very impressed with the product for the price.
Ohio Crankshaft |
They sell a 632 short block for 5K, just needs different pistons to lower compression, which they will do. Don't know how you would piece one together for that$
Check out competitionproducts too they have some good prices and name brands
Originally Posted by dunnitagain
(Post 4605098)
No need to cut cost on a big inch, hp engine, I'd go with a Callies crank and Oliver rods and Diamond pistons to go along with your Dart block....jmo
I'm looking for around 800hp , same torque . Wont ever be supercharged so I think the Callies , Oliver rotating parts are overkill. I also want an off the shelf piston for simplicity of repair . Looking to do a 6.535 rod , 1.270 pin height with a 20-30cc dish to keep compression down . Just curious what has been run successfully in the medium price range parts.
I would not short change the crank at all, 632's were breaking cranks, had several guys I knew that were racing(I know different deal) but all had cranks that just broke... so what out there
(Post 4605253)
| All times are GMT -5. The time now is 08:59 AM. |
