-   -   454 CLOSED LOOP COOLING Question (https://www.offshoreonly.com/forums/general-q/352256-454-closed-loop-cooling-question.html)
OSOUSMC 02-11-2018 01:33 PM
Hello, thanks for viewing. I'm putting together a Scarab 22 with a Gen 6 closed loop cooling system 454HO. Question is; while installing the aluminum intake manifold, my Fel-Pro marine gasket kit came with stainless restrictor plates for the intake gaskets. "DO I NEED THESE or just discard them. Thanks all!!
f_inscreenname 02-11-2018 09:50 PM
I don't use them in Mark IV or Gen V BBC's
Mbam 02-12-2018 06:14 AM
I think you are talking about restrictors for the heat riser passage in the center. Yes use them or even better block off completely.
